Results 1 to 3 of 3
Thread: Sound Card to Reciever problem.
    Nov 2012
    Default Sound Card to Reciever problem.
    Ok, so here is my issue. My computer is a little on the older side, so I had to purchase an external sound card for it. It's a Vantec MBA-200u. I have had no real issues with it. Have it hooked in to an older KOSS dvd/receiver via optical, and get nice 5.1 surround out of it.
    Earlier this week, my receiver died, presumably from old age. I picked up a used JVC RX-6030VBK to use as my new receiver. Got all the connections plugged in, and for whatever reason, it now only picks up from front pair. It won't register the rears, sub, or center channel.
    Now I did the normal troubleshooting on my receiver and in the sound menu on my PC, to make sure I had the right output set, and the right input on the receiver. Even made sure the surround setting was properly turned "on" on said receiver, and yet I am only getting sound from my 2 front channels.
    I was wondering if anyone could offer some sollutions as to why my receiver does not want to pick up all my speakers?
    A.B. normal msmrx57's Avatar
    Jan 2008
    Western Wisconsin
    Default Re: Sound Card to Reciever problem.
    Have you tried the receiver with a different surround input? I've had an older surround sound receiver where when it started to die the rear and center channels went out first.
    Now, off to the basement to do some fiddling with the rods and such.
    so far left of center i'm in right field
    Moderator TLHarrell's Avatar
    Jan 2012
    Morgan Hill, CA
    Is your source actually 5.1 channel?
