Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
Thread: Project MEHA and SEPA
  1. #21
    Fox Furry crenn's Avatar
    In the shadows behind you
    Default Re: Project MEHA and SEPA
    MEHA is mostly built, just now I need to get some spare parts due to broken components, mainly a thread being stripped. I'll post photos soon enough.
  2. #22
    Oct 2007
    Kinshasa, DRC
    Quote Originally Posted by crenn View Post
    I hope...
  3. #23
    Well, SEPA arrived at my uni today with some 800mAh 2S LiPo batteries (I have to order in the 1Ah 2S batteries for SEPA, but I can test with the 800mAh batteries) and I've assembled it. Like the Firefox EP200, there is pretty much no instructions included with it, however, it's not hard how to figure out how to assemble the plane. The servos are glued in place, so I'll need to work out how to remove them and replace them with the HXT500 servos I bought which are a lot better. But before I fly, I wish to mod the plane slightly, putting in new servos for better control, put in actual hinges for the control surfaces (currently it's just very thin foam holding on the ailerons and elevator, it's asking to break mid flight), adapting the 'cockpit' area to accept my little camera that I bought with MEHA and also to house some of the electronics I'll be putting into the plane. Also properly charge up my cheap NiMH batteries.
    So on the shopping list:
    Scalpel
    Foam-safe Glue
    Hinges
    1Ah Batteries
    Custom PCB to hold electronics
    Nerves of steel to cut up a brand new plane
    Epoxy and some thin fibreglass
  4. #24
    I'll leave these here:
    More to come soon.
  5. #25
    Jun 2008
    MA
    that first vid would look SOOOOO COOOL in 3D
  6. #26
    Sadly, I don't have 2 cameras.... and firstly, I really need a better camera! The Samsung HMX-U10 that I use is ok, but it has a lot of flaws. At least it can record in 720p 60FPS or 1080p 30FPS.
  7. #27
    Oct 2008
    MD, USA
    Looks good...now get that bird in the air!
    --Benjamin Franklin
  8. #28
    Jun 2008
    MA
  9. #29
    The problem with using an Arduino as the base of a autopilot, you don't get enough performance for it to work well enough. You'd need multiple arduinos connected to each other to get the desired results. It's possible to get it close using a couple of arduinos, but not 1. If you ditch the Wirish libraries and only use C/ASM, then you might be able to get it running fairly well on 1.
    In other news, we had a small incident this morning. 2 LiPo batteries were accidentally plugged into each other, I'm currently repairing the batteries due to both batteries needing new plugs. Pictures to come later.
  10. #30
    Nov 2010
    Idaho, USA
    Shocking news!
    Tri.fecta
