me
Hey!
Recently purchased your complete kit, and i'm really pleased with it, execpt one thing. I have a leak...
Now I have tried just about everything, and i'm starting to get a little fustrated. The leak is coming from the wires that come out of the pump/res! It is circumstancial though. It only leakes when the pump is not running and the cap is on. If the cap to the pump is off, no problems, and if the system is running, again no problems. However, I cannot leave the system off with the cap done up! Not much good!
I'm rather concertain about the fact it is coming from the section with the wires, and the gel stuff that bonds the wires looks a little odd. It doesn't cover the entire section. In case I have lost you, i'm referring to the clear/milky sealent on the pump that holds the wires.
I have tried with different amount of coolant in the system, but to no avail. Filled right up I still get the leak, mostly filled still get a leak and if I leave it so the is some air in the system, again, it leaks. Anyway, any ideas would be appreciated as I cannot really use the computer in its current state. Thanks,
Nat
