Waht's the best way to prep a textured surface like this:
for painting? I don't want to lose that texture if possible, although I suspect the paint might not sit too well on it, and run into the channels anyway.
It's the frame for the front panel on this:
There's some damage to the top left side, so smooth may be the way to go.
I was thinking about using body filler then sanding it until I can see the pattern starting to show. That would give me an indication that it's even.
I'm planning to use acrylic from an aerosol. Metallic blue.
