I'm no good with joining 2 pieces of mater together so I'm asking for more help.
I thought of 2 options to use. Here are my small models of my ideas.
Option 1
End to end. IDK if it has a joint name or not. Homemade L brackets to support.
Option 2
Miter joints for the top and bottom (or sides) and a straight piece for the other supports. Homemade L brackets to support.
Would one of these options work? Or should I do something else? It needs to be pretty sturdy with all the weight.
Cheers.
