Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Best NVIDIA card under $100
    Oct 2007
    Kinshasa, DRC
    Default Best NVIDIA card under $100
    I need to upgrade my wifes 8800GS and I'm not sure what to go with. I don't want to spend any more than $100.
    Let me know what you all think.
    Thanks in advance,
    Fuga
    Water Cooled pcclan's Avatar
    Jan 2009
    Edmonton,Ab
    Default Re: Best NVIDIA card under $100
    there's this http://www.newegg.com/Product/Produc...82E16814127535 79.99 with free shipping or this http://www.newegg.com/Product/Produc...82E16814125366 $79.99 with $6.98 shipping edited
    Quote Originally Posted by lastweek View Post
    Not only will it probably catch fire to your house, it will probably shoot peices out of your case and kill your cat. make sure you video tape your expierment.
    Quote Originally Posted by StormRider View Post
    Write your will before you turn it on
    Oct 2007
    Kinshasa, DRC
    How much does memory clock matter? If alot then this one is 2x better memory clock but slightly lower on core clock and shader clock.
    http://www.newegg.com/Product/Produc...82E16814121426
    Jun 2007
    Your cookie jar
    You can find GTX460's hitting under $100 recently. That should stomp on the gt430.
    Oct 2007
    Kinshasa, DRC
    Can you link?
    The only one I saw was this Galaxy one after the rebate... never heard of the brand before...
    rawrnomnom diluzio91's Avatar
    Jan 2010
    galaxy is a pretty decent brand from what i've been hearing.
    Not dead yet
    Oct 2007
    Kinshasa, DRC
    After reading the card more the only thing better is the Stream Processors and Memory Clock. The Core Clock, Shader Clock and Memory are better than the 460.. does that matter? or is it just a really low end 460?
    Oct 2008
    MD, USA
    The stream processors are the most important factor. Sort of like cores on a CPU. 17% faster clock with 250% more cores is way more power.
    --Benjamin Franklin
    Jan 2010
    Not dead yet
    Jun 2007
    Your cookie jar
    Galaxy is a good brand. Evga has B-stock 460 768mb cards for 90$. Don't have the time for a link, but google evga b-stock and its right in there.
    There's a world of difference between the gt430 and the gtx460.
