Custom Title Honors
Re: Small flat LED replacement
that works too. you probably wouldn't be able to tell the difference in light output between using a 156 or a 180 ohm resistor. the 180 would be "safer" to use probably.
Ok so I bought 25 of each LED (couldn't get less) and 10 of each of the resistors. We will see how it goes.
