Hey all,
Been quite a while since I was on here. I'm looking at making a new PC and want to water cool just the CPU. Maybe add the GPU later so expandability would be nice.
The case:
http://www.newegg.com/Product/Produc...82E16811129087
I've looked at CPU kits but they are not expandable.
http://www.newegg.com/Product/Produc...82E16835181015
Now since I'm putting $1,500 in to hardware, I would like to make the water cooling under $400. That being said I saw the H20-220 on Swiftech's website and I think its pretty slick. http://www.swiftnets.com/products/H20-X20-Edge.asp An all in 1 system that is a good brand. Anyone use this? It is compatible with my case according to their website. Is this system expandable to include my GPU at a later date?
I've also seen this setup:
http://www.swiftnets.com/products/H20-220-ULTIMA-XT.asp
A bit more work to install and not so compact. Anyone use it or can recommend a different product?
As I said I really like the H20-220 product for being so compact.
Thanks in advance for the help!
