Wow. You're the third I know that is doing an N64 build.
Ok bad news guys. Finally got my fan in the mail today (it's a 30mm 12v), plugged it in and booted up the Mobo. While the fan did start spinning, I got the same error message telling me there was a fan error and it shut off. I tried another fan (5v) and the exact same thing happened. What's the deal? Is there something I'm not getting?
If you have an 80mm or bigger fan, try plugging that in and aim it at the heatsink. It could be that (assuming the fan connector on your 30mm is 3-prong rather than 2; the 3rd prong tells the 'puter how fast the fan spins) the mobo is detecting that the fan is running slower than the BIOS's minimum fan speed setting, thus generating the error. An 80mm or bigger fan would spin fast enough for sure, so that could be an easy way to either fix the problem or rule out a possibility.
It looks like from the mobo photo that there's only 1 fan plug, so you can't have plugged the fan in the wrong place.
If that doesn't work, honestly I'd look in to replacing the board. I know how irritating it is to think you have a system put together and then have to replace it, but I'm not sure what else could be causing the problem. You might also try resetting the CMOS by either pulling the coin-shaped battery out for a few seconds while the system is off, although I wouldn't really expect that to work.
Okay! Finally got an 80mm one in the mail today and it powers up! Thanks so much everybody for helping out a noob. This thread can finally be put to rest .
Hi,
I know I am late to the party, but here is my solution.
Use a socket 7 Heatsink and fan. Then cut and bent coat hanger wire to make a spring clip to hold the HSF using the two loops on the motherboard. Use the northbridge cooler as an example to work from, but measure the distance for the processor loops as it is a larger spacing.
Sorry about the image size/quality but I think it serves the purpose.
My problem is that i can get the power switch to turn on, and the cpu & psu fans spin, but there are no beeps and there is no display.
What sort of power supply / adapter are you using and where did you get it?
Thanks,
Cyborg28
