Hi All!
Long time reader, first time poster.
I have build many a custom PC for myself, but usually with minimal case modding (I add a few lights and replace some fans, but that's it). I want to take the next step. My design is a bit ambitious.... After all, I have all the artistic abilities of your common household slug. But, I have big dreams!
The case I want to build is loosely based off stargate atlantis. Specifically, I was thinking of attaching a stargate to the side of the case (maybe have the fan in the middle of the gate) partially buried in rocks up the side of the case. I was planning on making the rocks out of a light weight hydrocal.
You really don't need to know any of the above, but I am briefing you for more questions that may come in the future. :-) The real question is next.
I also wanted some ancient design in there as well. If you remember the atlantis series, they had these tubes of water running up in the background. I am going to have water cooling, but I also want to incorporate some of the blue water pipes look (running from the bottom of the case to the top); but probably not hook that up to the cooling system (would take quite the pump, and a lot of messy tubbing).
So, I was thinking for these, I could use a colored resin like someone refered to in another post (http://www.creative-wholesale.com/Easy%20Cast.html) maybe in some clear plastic tubing.
Question: How can I get a bubble effect in that tube? It doesn't have to move - just casted bubbles would be fine.
Thanks in advance!
