I'm working on this mod involving an old case. I have a lot of cutting to do on the rear panel. I have a dremel type thing, but it's rather underpowered and making a two inch cut in this case will consume one cutting disc.
So, would an angle grinder be the way forward? or would it be too fierce? The material is 1.5mm thick.
Here's what I intend to cut:
The critical cuts are already made (with the dremelly thing), so absolute acuracy isn't that important.
I've used an angle grinder before, but not often... I expect I'll get it 'somewhere near' then finish off with a decent half-round file.
