Results 1 to 10 of 17
Thread: running LEDs from battery
    The SlackMeister
    Brooklyn
    Default running LEDs from battery
    hey, i never worked with any types of lights or LEDs so i have no idea how they work. my friend wants to put some kind of lights on his bike, just for the fun of it. i suggested him to try LEDs coz they are cheap. so my question is, can i use AA batteries or other type of batteries to power LEDs. if yes, how many LEDs can i put on 1 battery and how do i connect them. thanks
    Water Cooled
    Default
    id recommend to look on google for some basic tutorials. you can run as many leds as you want, but you have to be carful how you hook them up and the voltage of the battery.
    different leds draw more current and need more voltage than others. bigger and brighter leds will need stronger batteries but it is all doable. an average led draws around 0.2mA @ 2V, you can hook them up in parallel on a 1.5V battery and you should be fine.
    Overclocked Guttenaffe's Avatar
    Ohio
    Default
    Please read my post here about LEDs:
    http://www.thebestcasescenario.com/f...8&postcount=20
    To add a little more to that:
    If you want 10 LEDs off of one battery and they are all the same voltage and require the same current you can use one resistor. Example: You have 3 LEDs they have the bias voltage of 2.4V per LED and 20mA max current draw.
    You can use a 9V battery and power these those LEDs using that formula
    ( 9V - (2.4V * 3) ) / 20mA = 90Ω resistor to give the series 20mA current.
    This is the correct formula for LEDs, some webpages and calculation web-apps are incorrect because they do not understand semiconductors.
    You see in all Diodes, there is a forward bias voltage and a reverse bias voltage. The forward bias voltage is for use to make the LED light up. The reverse bias voltage is the voltage that will make the diode "break down" when you have that much potential energy (voltage) such as a positive source on the negative side and a negative source on the positive side of the diode. Once this is broken the diode will become useless and destroyed. We do not want to mess with this, as we wont out LEDs to be light up, this is for other things and can be ignored.
    The Given voltage for an LED is the forward bias voltage. This is how much potential energy (voltage) is required on the correct polarized side for current to flow though the device.
    Ok, we hook up our voltage source and wow, it just blinked on an died. What happoned?
    That is due to the other given information about the LED. There is a current for the LED given (normally around 20mA which is .02A) that is the maximum amount of current that can flow though that LED without damaging it. This is also the exact current you must meet to get the proper mcd (brightness) out of your LED. LEDs do not really use power that is "measurable" that is their magic and reason they will last for so long as ‘flashlight bulbs.” The problem is we have to use a resistor to limit the current that will flow into an LED to keep it from dieing. This resistor is the major sore of power dissipation.
    The resistor forumula is explained in my other post.
    Maybe I should ask som1 to make my post a sticky somewhere or see if I can write an article for posting on here.
    -Gutte
    No, I'm not a compleate Idiot!
    Some parts are missing.
    Southern Modder Matthew's Avatar
    Ruston, Louisiana
    Default
    Lol, he wants to put lights on his bike...post pics of that when its done.
    How did you come to trade the fiddle for the drum?
    Ohio
    Default
    Maybe he wants lights as "ground effects" such as you see on cars? Or does he want to use them as safety devices?
    If he wants light as something for just the sake of glowing color I'd recommend EL lighting, they have 3V converters and also 9V converters for EL-wire, EL-tape, and so forth.
    -Gutte
    The SlackMeister
    Brooklyn
    Default
    my friend is VERYYY into cars. he loves riced out ****. he wants lights just for the glow like neons in cars.
    EDIT: if he gets something like this http://www.elwirecheap.com/eltape.html how can he hook it up to a battery? dont forget i dont know any of this electrical stuff so plz dont use big words.
    EDIT #2: something like this http://www.elwirecheap.com/noname31.html will do the trick, right?
    EDIT#3: got the perfect kit http://www.elwirecheap.com/elwibikit.html what you think? also do you know how is battery life of thise things?
    Ohio
    Default
    http://store1.yimg.com/I/glowingstuff_1834_862869
    From that webpage you posted there are the portable inverters for EL devices.
    As to that kit, if that is what he want then it will work fine.
    Batterylife, no idea email and ask their sales team.
    -Gutte
    Brooklyn
    Default
    I would hit a rice shop and use the little LED air caps that I see people using. They use what I presume to be little watch batrtries and must last a long time. Depending on the size of the threading he can even put them on his aircaps.
    Overclocked
    Toronto
    Default
    Zed's got a good point. Those little valve stem caps are real good. They last a long while, and it's the easiest method to get what you want, without heavy soldering or math.
    When computers collide, Bob is born
    And remember, boys and girls, it's better to say nothing, if that's what you know.
    Water Cooled
    Default
    these are really not big words, if you dont understand the basics of electronics, and you are not willing to learn then forget it. get some premade led lights as it was posted before if you dont want to mess with it.
  1. LED's and Resistors Guide
    By Whisp in forum Electronics
    Last Post: 01-06-2010, 06:39 AM
  2. Leds Leds Leds
    By maximan1 in forum Motherboards, Processors, & Power Supplies
    Last Post: 11-18-2006, 09:32 AM
  3. Led's
    By gaz_the_chav in forum Modding Q&A
    Last Post: 10-14-2006, 07:55 PM
  4. Demystifying LEDs.
    By xmastree in forum Electronics
    Last Post: 05-07-2006, 09:14 PM
  5. replacing fan LED's ::Q::
    By yawnbox in forum Modding Q&A
    Last Post: 08-18-2005, 04:46 PM
