Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Can you recommend a good Airbrush/Compressor for case modding?
  1. #21
    Sep 2005
    Doylestown, PA, United States
    Default Re: Can you recommend a good Airbrush/Compressor for case modding?
    Hmm, I don't know what to say other than make sure to shake the paint well? Lol, and yes...
    BE SURE TO ALWAYS CLEAN YOUR AIRBRUSH AS SOON AS YOU ARE DONE!!!!
    I also learned the hard way... and lost quite few brain cells to the acetone that I had to soak it in for an hour... not fun. That is precisely why I strongly recomend the airbrush-ready waterbased paints for beginners.
    Typo:
  2. #22
    I will make it a habit
    The smartest thing to do is learn from others, so ill take your word on it
    I picked up some airbrush cleaner solution and have been using it when im finished and also between colour changes of course.
  3. #23
    So tybrenis, i see createx also makes a line called "auto air". Do you recommend these for case modding by chance? it seems they are made for cars, and since cases are metal would these work better?
    Unfortunatly they seem to be about $2 more expensive per bottle also
  4. #24
    Sep 2005
    Definately, if you really want the best paint for your case, you will want to use auto-quality paints. Just remember that surface prep is very important, even if you are using auto paints. Tybrenis tip: just because you have paint stripper doesn't mean you should use it: sanding down old paint will work much better than just removing it all together.
    Typo:
  5. #25
    Apr 2006
    Philadelphia
    visit eastwood.com they have great bundles for cheap.
    No genuis is a organized worker.
    PROJECT "2GHz OF THUMPIN BASS" HAS BEGUN!!!! CHEAK IT OUT IN THE "PROJECT WORKLOGS" AREA.
  2. Project: Unnamed
    By Omega in forum Works in progress
    Last Post: 08-31-2007, 01:50 AM
  3. Aero's Guide to Modding Part 2- Materials
    By Aero in forum The Rookie's Nook
    Last Post: 12-29-2006, 04:49 AM
  4. Modding a case - need newbie tips ^^;
  5. my first few steps inot the modding world
    By SaWBLaDe in forum The Rookie's Nook
    Last Post: 11-12-2005, 06:20 AM
