Just wondering what your averege water temp is under regular use and load.
Before i got max 32 degrees celsius on load, but after I got two X1900XTX Crossfire it maxed out on 45 degrees C. Not supprising actually. Only got a singel 120mm radiator.
Jes, Im a bloodi nowegian wit aløt of f**ked up gramar.
(Sorry for all my mispelling. )
My latest mod: Media Chair
p4 prescott 2.8ghz @ 3441 mhz
with 5700le
running 39C idle (well.. running the server) and 45 load (playing and hosting the server at the same time)
ok. Thanx for the reply!
What kinda water cooling do you have? Single og double radiator?
keep in mind, that water has a much better thermalconductivity than air, i saw the actaul figures once (i think it was wikipedia.)
if you go WC, then also go with copper waterblocks for the best thermalconductivity.
