im new to this forum. just made my acc so i can post this question.
im
working on modding a armour + case to fit a 360 mm rad at the botom. but that is not what i need help with.
i need too know ho the hell i can paint the mouting bracket for the swiftech apogee xt. i sanded with 120 grit sand paper but the primer wont stick. ive applied 6 layer of paint. i let each layer dry of course. the paint jsut wipes off and leaves nothing there its like it was never even on there.
now off topic a bit but do i need to sand the entire case before priming or can i prime over the silver and just paint.
and last question any idea on how to pain a rad easily well strip the paint easily then paint it. pump to.
i have been searching google and every forum i can possibly find but just like there are barely any mods for my case. apprently for what i want to do is even rarer. so please so help would be apprciated.
thank you all for the help
ps this is my first mod so go easy.
