Anyone have an Antec 300 that can test if the premodded cooler master side panel has a good fit on the case? Specs didn't show up on newegg site.
water-cooled m-atx: (sold)
http://www.thebestcasescenario.com/f...ad.php?t=15368
Diary Of a Caffeine Junkie: Powered by Rockstar (dead)
http://www.thebestcasescenario.com/f...ad.php?t=13786
Better yet, maybe just a template of the side window. the fan on my stock panel is about in the right spot.
The dimensions of the 690 lead me to believe the side panel is too big when eyeballing the full dimensions minus the fascia.
Also the 300 doesn't use a standard sliding panel while the 690 looks like it does with those tabs on the end of the panel. The 300 has a metal U channel that hinges on the chassis that swings out 50-60 degrees, then is held in by the screws. You don't slide it in, you put it on at an angle then just drop/set it down.
EDIT: You should be able to fit a similar shaped window on the 300 though. You would just have to do it yourself. Here's a quick window I did for my little brother's 300 a while back.
Not my picture, the brother's. Don't have another.
Just round out the edges and draw the angle out more.
