Results 1 to 3 of 3
Thread: Wireless logitech z5500?
    Default Wireless logitech z5500?
    is there any way to connect the speakers up wirelessly? my living room is very large, and i dislike having wires all over the place.
    . Spawn-Inc's Avatar
    Feb 2007
    Default Re: Wireless logitech z5500?
    i don't think i've ever seen one, you would have to DIY something i think.
    you would have to get external power for each satellite then wirelessly send the single to it.
    Sound: Logtiech Z 5500
    Dec 2008
    You can run them under the carpet or behind the trim. It'd only take a few hours and would be a hell of a lot cheaper than trying to mod the speakers.
    PS3: CaptBuzzCooler
