Water cooling an Xbox 360
I just finished fixing an RROD Xbox 360 (floated the solder) and now plan to water cool it. I've been looking at the XSPC Waterblock http://www.tilatech.com/products/XSP...ter-Block.html just want some ideas on an internal radiator and pump small enough to fit in the case. I plan on having this all internal and am willing to hack up the inside if necessary.
Re: Water cooling an Xbox 360
You should be able to squeeze a DDC in there, and if you can find one of those 2x40mm radiators, that could go where the regular fans are.
Edit:
Here's a 360 watercooled with DDC and the 2x40mm radiator.
Edit: 2x40mm is made by Magicool.
They also tried a 120mm rad as well. Not too much info though, and I'm not sure who carries that 2x40mm anymore.
Slightly off topic, but anyone know what temperature gauge he used?
Looks like this one from Aquatuning
Or
This one is almost identical, also from Aquatuning
Edit: Or this. I think they are actually all the same display but a different config for the tubing ( different size / inline / etc ).
Thanks guys, I plan on taking my FREE Xbox 360 I got from a friend to work tomorrow (yes i fixed it) and putting in some red led's (I find it humorous) in the power button.
Plans:
side window
liquid cool
red leds
custom paint job
will post more in Works in progress section...... stay tuned.
