Results 1 to 4 of 4
Thread: paint question
    Wink paint question
    for the interior of my case I'm painting jet back with a red or purple glitter overlay...(I havent decided on final glitter colour)...
    My question is this:... Is there something I have to do after I paint the glitter on?... eg: do I have to seal it with something or is it ok just as the glitter spray paint?
    eagerly awating reply
    thanks ^DP^
    Feb 2006
    New Zealand
    Default Re: paint question
    http://case-mods.linear1.org/mirage/1/
    Check it out. Are you after this?
    Case Wizard
    For air bursh paint there is a perl / glitter that you add to the pain before you spray it on. Gives the same perl look that you can see on come cars.
    naw I was going to use this http://www.dickblick.com/zz014/16/
    over the top of jet balck car quality paint so that when I put lights in the case it kinda has a sparkle to it like the night sky kinda thing... I just wanted to know if I had to seal it in anyway but I guess tryal and error will have to be the way...
    thanks anyways guys
  1. Cutting steel cases and acrylic paint question...
    By gold_leader64 in forum Modding Q&A
    Last Post: 08-22-2006, 02:41 PM
  2. Knight Rider CWC
    By marquee in forum TBCS Featured Worklogs
    Last Post: 08-02-2006, 07:42 AM
  3. Paint question
    By jareth in forum The Rookie's Nook
    Last Post: 06-11-2006, 02:41 PM
  4. Acrylic paint question
    By egroj in forum The Rookie's Nook
    Last Post: 08-09-2005, 02:29 PM
  5. Monitor Paint question
    By jobasha3000 in forum The Rookie's Nook
    Last Post: 07-28-2005, 03:04 PM
