Hi.
I'm one of those guys who plan and develop ideas, but never seem to complete, or even start them (at least if you ask my girlfriend). Anyway, i've been going back and forth on this forum and others, collecting ideas and I think i'm ready to present the one i've been working on.
Since i'm not really into taking an existing case and modding it, i'm more into building from scratch (and yes, it can be tricky, but bare with me here).
The idea is the following.
Think of a brain, in plexi, with sanded (or cut) sulci (the valleys). Now, spread out across the brain will be white LEDs which I aim to connect to an IC. The IC in turn is hooked up to the computer via the serial port. The LEDs are meant to flash in random pattern, but the frequency of the flashes is based on CPU usage. I think that this would look pretty neat, especially when CPU usage goes up, such as playing compressed media or compiling stuff.
Am i making any sense so far?
The brain will be hooked up to my mythtv box (running Gentoo linux) and getting a program to send CPU load to the serial port is the least of my worries.
Now to a few questions:
1. Is there anyone how know of a pre-manufactured board that can handle the signal from the serial port in the mannor described? A small IC which randomize activity over LEDs.
2. Do you think the project is feasible?
3. (this is my biggest dilemma right now) Should I paint the brain (at least on the gyri (ridges)? Or, should i put glossy plastic on it, to make it look more moist?
The third question could probably be dealt with way later... as I said before, I'm not really good at making my project come to life, time and whatnot is a big factor here. But if I do, i'll promise to show the progress here.
best
