Hey guys, I'm practically new to the modding world, so I'm sorry if I don't know much. I'm going to try selling my current setup on ebay and build another setup using the new socket 1156 Core i7 (the one that's like 280 bucks) for a budget, but high(ish) performance pc. Anyways, I'm planning on putting a MAJOR water cooling system in it. I've decided on the Swiftech MCP655 for my pump, but I was thinking of using 2 or 3 of those in sync as to increase or help the head pressure and flow rate through the system... Do you guys think this is a good idea, I've seen it done before with the smaller Laing versions (can't remember what they're called, similar to swiftech MCP355). I can't tell you everything that's going into the system as to keep it a surprise and make a work log on this site as I'm building it. The parts would be:
2 or 3 X Swiftech MCP655 Pumps
2 X 4x120mm rads
2 X 1x120mm rads
4 X graphics card waterblocks
1 X CPU waterblock
1 X chipset waterblock
If you guys have any suggestions or ideas, please let me know :]
