From Matriarch to M2, here's the rebuild in progress. Been working on it since last Thursday after getting the cheap case. This time I expect the cost to beat Pprz even with the casing counted. Grabbed one of the worse brand in casing, iCute. Its a 2nd hand and paid only RM25 (approx US$7). Lemme try to reorganize the way my worklog goes.
Since I now have one whole apartment to myself, that means more space = more panels to be worked at once. So work's gone pretty effin fast as I know more or less what to build and how to start molding.
Theme
I don't wanna stray too far from the original Matriarch itself, so this time I'm going for a half human half dragon grotesque theme that wraps around the case except for the top panel. Here are some sketches.
Color combi will be black base, blue shades with green highlights.
Materials
Cheap case and a lot of paper
Side Panels
I'm trying to get the case to look more of a whole instead of each panels having their own different designs as in Pprz. So in this WL both panels will look the same.
To get an idea how it should be aligned with the face at the front
Now you get a better idea of the whole thing on sides and front.
Haggling if I should add ribs to the curves. Keeping it low profile for now.
Front Panel
This is a headache as everything else revolves around it. If the face doesn't get completed/dried, no work goes on until it is. Still halfway working on it as its still damp, probably detailing by tomorrow.
Nostrils... LOL, so it can do something like below in its free time
Keeping a bezel on the 2nd column to support the top of the head.
For ROM stealthing, xtremely thin
Still need to work a lot on the cracks in between and the size. Then detailing as well. The cheek looks kinda small and the eyes a lot bigger than it should be.
Base
Yessur, an extension to the base. Nothing will be in it, just a solid block of paper (as I don't have any tools with me, again). Kinda hard to wait on it, the thickness made the sun looks useless as well.
Dumped stuffs
Some random thing at first for the top panel. Scraped.
Letters which IDK where to place. Scraped.
Top panel hasn't been touched yet as I leave the case upside down to finish the base first. That's all for this week. Be back next week. Oh, about to start a new job, finally after 1.5 years of "retirement" lol.
