Ok, I'm looking into water cooling. I'm currently using the ThermalTake Prowater 850i, but it has a copper block and aluminum radiator. Bad idea, I am told. I'm looking at a passive solution, but the heat exchangers I'm looking at are aluminum. I've looked but can't find anyone that makes aluminum CPU water blocks. ??? I've found aluminum blocks for VGA, chipset and MOSFETs but no CPU blocks. Does anyone have any idea if these even exist? I figure is the entire loop is aluminum, I can avoid the dreaded galvanic corrosion.
