Results 1 to 10 of 16
Thread: Anthrax
    ATX Mental Case AntraxLife's Avatar
    May 2009
    Default Anthrax
    Soo this wil be my first project and proberly the most learningsome
    ill be making a photo movie or something like that that will show the entire *build. ill also add 2 pics with this post to show the case at the moment
    i must say that this is just the best case to mod, perfect standard size.
    45cm long 40cm high and 20cm width.
    it will become a case with cut out biohazard signs and the text Anthrax painted in green on de side and top, also i will chance every led in my case for brigth/dark green led's make green led's shine trough the cut out signs
    anyways for me its the first time so i can need all the help from the pro's and the less pro's *everybody is better then me *
    *im just modding not building a new case
    Pics:
    The case normaly
    Opened
    Running, Gonna chance the blue led's for green ones
    The Sides come off as well as the top.
    AntraxLife,
    Hope you guys can give me all the tips i need
    *first one i need: what kinda stuff you use to paint your case*base colour?
    *second one i need: How do you cut your things out of your side''panels'' without a little disk grinder?
    May 2009
    Default First try: Project-Anthrax
    ok so im new around here and ready to start my first mod
    if youre wondering who i am: check the topic about introducing yourself, im in that one
    So my idea was simple: mod my current computer
    > http://www.thebestcasescenario.com/f...422#post243422
    i was kinda going for painting it black with green*virus like green* Biohazard symbols on the sides and the top...
    but i came with better ideas when i was beginning
    at the moment im actualy cutting,drilling,sawing and trying everything i can to get the symbol *Biohazard one* on the top of my computer out.
    im almost done with that and i'll be posting some pics soon
    im also replacing all of the blue led's in my pc for green once's so there will be green ligth comming out of the top
    once i am started you'll catch the idea but for now you all have to waite for some pic's and update's
    Bart Jeninga
    AkA: AnthraxLife
    p.s. if you find my name weird or bad spelling*CORRECT ME*, its proberly becouse of me being dutch.
    May 2009
    Default Re: First try: Project-Anthrax
    Quick update:
    I could borrow my uncle's Dremel so now it will go faster and looks better
    i also made the dissision to make a side window with some 3mm plexiglass
    I got one question about painting: i got some mat black paint in a can but what do i need to do before i paint it?
    i took some pic's that will be in the next post
    AntraxLife,
    Bart
    May 2009
    Thanks @ Zero helped me ALOT! and of course thanks for your huge confidence
    my mom got a HUGE plexiglass sheet from her father *wich is now kinda dead...* and i can use it for a window its about 2m by 1,5m and 3mm thick so i have all room for error
    finely some pic here me and my first time with the Dremel! i was scared when i put it on 9 or 10 for the first time
    Me and the Dremel
    http://img190.imageshack.us/img190/3011/img1208.jpg
    and the work done after 10 minutes
    http://img190.imageshack.us/img190/9190/img1212.jpg
    *remeber this is my first profect *
    -AntraxLife
    May 2009
    and here come the next serie photo's, this will be the last ones for the upcoming 1 and a half week seen the fact that my exams start tomorrow and en next week thuesday.
    How the top was
    and after i done some work on it with the dremel
    and the side, cut out the 3 part window and begun working on the letter's
    See you guys in 1 and a half week, wish me luck for my exams
    -AntraxLife
    May 2009
    well this is a quick update, even if i can't mod, i can work and earn money for the newest thing i dicided*correct me please! * to put in: Watercooling!
    i am really bad at sketchup or any programm like that so im gonna take some pic's of the drawings i did i can design but i can't make, kinda sucks... 2 of 6 exams done> tomorrow one more then 4 days of nothing and then last 3 to come... almost back to modding!! yaay
    May 2009
    Hoerah another update this one will be a bit disapointing seen the fact that i just had 3 exams and now have 4 days off and then the last 3
    i just could sketch some new idea's out tomorrow ill be sketching out the front and then other side's i haven't thougd off
    this one features a small chance in the size and overall look of the window i cut out kinda still thinking if i should frost effect the edges of the plexi...
    anyways,
    the middle window will get an diamond shape and the 2 side window's will be arching ober the middle one...
    the red lines and area's still need to be cut out... those are as wel the area's that i just came up with
    the blue one's are the one's already cut out or like the letter's still need to be cut out
    i hope to get back to cutting tomorrow and the 3 days after tomorrow so i can get most of the cutting done
    -AntraxLife
    Im Dutch... can i say anything else?!?
    May 2009
    thanks SgtM...
    quick update .. pics coming soon
    i got the Coolermaster Aerogate 2 fan controller and atm i have 9 fans mounted in my case there will be two more in the front im cutting that as wel... but i need to get new cutting weels for the dremel becouse i have gone trough all the ones i had
    i was wondering... can i make my own resevoir and stuff and then just mount a fish aquarium pomp as the pomp and make my own watercooler?
    -AntraxLife
    May 2009
    cutted out the top and front window plexi still need to get new cuting weels for the dremel and need to get primer ... i started thinking about engraving the plexi post later on....
    May 2009
    thanks all this means alot to me seen the fact that im just a plain newb at the moment
    done my 5th exam today and tomorrow im doing my last one then ill be free to mod again
    also
    here are some
    some pics of the coolarmaster aerogate II it has a chancing ligth every 2 seconds orso... about 7 colours it also has a green colour between em and that is the led color im searching for at the moment got this free shipping site with fans (good ones) for 3 to 5$ so thats good if anyone want to know the site ill pm them to you.(dunno if im allowed to post it here)
    i got some paint: mat black and new cutting weels
    also made an sample of how the paint looks like... that is my old case btw
    The Aerogate II, i love it it is amazing
    Paint and cuttingweels
    Paint sample, nice and plain aint it? the brigth shiny green will stand out... or not? btw. it's my old compact small desk case.
    -AntraxLife
