i had just got some ram i had to send it back
the ram that i had in my pc was ddr 400 1gb corsair value select@225mhz dual channel (2x512)
i had purchesed ddr 400 1gb geil value ram dual channel (2x512)
when i installed the new ram iit booted then when it came time for the post beeeeeeeeeeep...........................beeeeeeeee eeep................beeeeeeeeeep.....
so i called tech support (i had tried every ram combo b4 i called and un clocked my cpu/ram just to be sure) and they confirmed that the ram was indeed incompatable that sux i was mad but what can u do
and it is not my mobo, because i had RMAed the ram back to newegg and they sent me another gb of the corsair and it works fine
but my advice: if you have corsair ram and you want to get geil ram DONT
there incompatable
hope this helps someone
int end everything worked out good 4 me
specs:
amd 3800x2 @ 2.35Ghz
asus a8n-sli mobo
evga 7800gtx(256)
wd sata 160gb hdd with 8mb catch
old wd 60gb ide with 2mb catch
external 80gb usb 2.0
coolermaster aquagate mini liquid cooling(it isnt too great but my cpu never hits above 40
enermax 535 psu (sli ready)
generic dvd burner(dual layer)(stealthed)
creative xfi xtreme music (i also have a platnum drive bay box thingey from creative) i woulda got the xfi platnum but i didnt want the remote lol
aspire x-navagator full tower case
ide usb 5 port card
2gb ddr 400 corsair value select(4x 512) @ 225mhz (450mhz ddr
winxp pro 64 bit
