Results 1 to 6 of 6
Thread: Reusing laptop display
    Anodized cvitullo's Avatar
    Apr 2008
    Ann Arbor MI
    Default Reusing laptop display
    After taking apart my burned-out laptop, I want to reuse a bunch of parts. what're the odds I can use the monitor? It *might* have the controller attached to it, I'm not really sure. Part number is LTN154AT01, but I can't find any information about it anywhere.
    If it helps, the only connector coming off the actual panel has 20 pins.
    AMD 64 X2 6000+ at 3ghz
    2GB RAM
    Diamond ATI Radeon HD 3850 512 MB
    eee PC 1000HA with 2gb RAM, 250gb HDD
    Feb 2008
    Detroit, Michigan
    Default Re: Reusing laptop display
    Not a very good chance that you can use it without spending a lot of money on a controller for it.
    Help my mini city
    Apr 2008
    Ann Arbor MI
    Was afraid of that. You know of any places offhand that sell the controllers?
    2GB RAM
    Banned Eclecticos's Avatar
    Apr 2007
    Florida
    Here is the service guide.
    You may be able to locate a controller, but it is doubtful.
    There is no way to isolate the display components
    without heavily modifying the controller board.
    Would not recommend any modifications inless you are trained and experienced.
    Apr 2007
    Florida
    Here is the Controller Solution Generator.
