Results 1 to 8 of 8
Thread: Fan filter material
    Default Fan filter material
    Can anyone recommend a good material to use as a fan filter-type mesh, and a place to get it? I'm going to need about 15" square for my the big frontal fan in my next project.
    It'd be awesome if it was black and semi-opaque, so that the inner workings of my computer were more hidden.
    Mar 2007
    Aiken, Sc
    Default Re: Fan filter material
    I remember seeing someone using lady's pantie hose stretched tight on a fan once for a filter.
    A big old Tease Apparently DonT-FeaR's Avatar
    Sep 2006
    Australia, south australia, Gawler
    fly screen wire... i am using it in vento
    you tease!
    A few ideas for you:
    "No See Um" Mosquito netting
    Pantyhose
    Room Air Conditioner filters
    Hope it helps!
    Over 75 Custom PC's in 20 years TheGreatSatan's Avatar
    Southern IL
    ^ I was searching your posts since you a new member and for a moment I thought "Spammer?"
    WH1T3 0U7
    Modified Thermaltake View 37
    Dec 2008
    After searching I realized this thread is years old so may as well post a link in case someone searches for it on the forum...
    http://www.uaf.com/Default.aspx
    I've found a lot of foams are too dense and actually choke the fan more than filter dust. I wish I knew the exact name for the plastic-like filters companies use in the 5.25 covers. Lian and Thermaltake in particular.
    PS3: CaptBuzzCooler
    Practice random acts of generosity Omega's Avatar
    Feb 2006
    A house
    I saw one build where the guy cut out a 240x240 square on his case, mounted 4 120mm fans and fitted the air cleaner/filter setup from a small-block chevy on the side. cheap, effective, much finer filter material than most computers need, and you can drive down to autozone and replace it for $5.
    Carpe Apenodytes halcyonforever's Avatar
    Mar 2008
    Oklahoma
    I tried using those aluminum mesh filters, I really didn't see any benefit, they would get clogged up and the inside still was dusty.
