thinking about a second loop to cool my harddrives and mem, should these parts do?
Koolance HD-55-L06 (HDx2) Hydra-Pak Dual Hard Drive Cooler
*** NEW *** Koolance RAM-35 (Single DDR/DDR2/DDR3/SD) [no nozzles]
- Nozzles Add Nozzle Pair, G1/4 Barb [13mm, 1/2"] NZL-V13KGB
Swiftech MCP355™ 12 VDC Pump
Alphacool Cape CORA 142 Convect Single - Black
- Fitting Size 1/2" Barb for 1/2" ID tube
*** NEW *** Bitspower 5.25" Bay Reservoir POM Version - Black
- Fitting Size Koolance Nozzle Pair, G1/4 Compression [13mm, 1/2"] NZL-V13KG
Delrin/Acetal "T" Fitting
- 3/8" Barb Fitting No Fittings
- 1/2" Barb Fitting Add (2) standard fittings
*** NEW *** Fluid XP+ Ultra LT w/ z7 - Non-Conductive 32 oz. Superior Cooling Fluid - Blood Red
Bitspower Black Shiny Sealing Plug - 1/2"
parts are over at performance pc
