Results 1 to 9 of 9
Thread: Abstract TBCS wallpaper
    Ceann na Drochaide Bige! XcOM's Avatar
    Sheffield (UK)
    Cool Abstract TBCS wallpaper
    with a twist on my wallpaper i've made:
    Mary had a little lamb. It bumped into a pylon. Ten thousand volts went up its arse and turned its wool to nylon!
    Oct 2006
    Spokane, Washington
    Default Re: Abstract TBCS wallpaper
    Thats just what I've been looking for! Thanks mate! +rep
    Sheffield (UK)
    your welcome
    Dec 2008
    I've tried many things with TBCS logo and honestly, I can't put it anywhere. It's a good design but when it comes to actually advertising it such as on a wallpaper or signature, it comes off too... I don't know the word for it... Animated?
    PS3: CaptBuzzCooler
    Sheffield (UK)
    i can remove it for you if you like and post it blank?
    Oct 2006
    Spokane, Washington
    Hmmm, I think I know what Buzzkillington is talking about. The new TBCS logo has a tendency of not being able to blend in very well as a "watermark" or whatever you want to call it.
    I think in this case a simple URL would suffice and look much better overall with the wallpaper. That, or maybe use the old logo design? You could probably just take the inner symbol, make it opaque and that would probably do the trick.
    Actually, speaking of opacity, maybe thats the problem? It stands out a bit too much as it is right now. So maybe make it more opaque? or maybe make it smaller? or both?
    Another thought would be to blend something in with the artwork. Maybe place the URL under and/or alongside, or even inside, one of the "bars". or something.
    Just some friendly suggestions! I think it looks fine as it is now, this is just being nit-picky.
    Sheffield (UK)
    updated versions based on sugestions:
    1600X1200 jpg
    1600X1200 JPG
    Oct 2006
    Spokane, Washington
    Yep, I like that second one quite a bit more. (would +rep you again, but you'll have to settle for a thumb. )
    What program did you say you use XcOM? I'll have to get it and start making my own! I can't do jack diddly in MS Paint! lol
    Sheffield (UK)
    gimp, was using 2.4, just upgraded to 2.6
