Page 1 of 18 12345611 ... LastLast
Results 1 to 10 of 174
Thread: Project: Vento..
    A big old Tease Apparently DonT-FeaR's Avatar
    Sep 2006
    Australia, south australia, Gawler
    Default Project: Vento..
    hey guys this will be my third case on the go... it is because i have pieces of moditor scattered between two houses and i am still trying to get them all..
    so here goes... project vento
    as the name kind of states.... it will be extremely vented..
    my base case is one my uncle bought me from an auction for $2!!!!
    no pics... sorry
    well first thing i did was drew up some pics for the front bezel idea.
    this was on the 20th november
    probably cant see that pic very well..
    the next thing i did was strip the case of its parts... top, sides, bezel, fans, feet and other stuff
    then i took a trip to the shops..
    also got about 1.5m of railing stuff.. for the feet....
    here is is cut into 4 strips.
    then i taped of the side pannel... right one... left one is at dads for some reason.
    drew out a design on the side pannels.
    let me clear this up cuz some people dont get it
    the side pannel will have the three holes cut out. then there will be about 2cm raiser then an alumi plate the same shape as the hole just an inch bigger.
    this will be clear when i do it.
    also marked out the top vent
    then with my not so famous hammer and screwdriver technique i cut them both out
    that is all for now... im a bit lost so ill do another post in a bit
    total view of the case so far - feet
    you tease!
    Sep 2006
    Default Re: Project: Vento..
    i did a mock up of the front of the feet.. ie.. side feet on with the cd rom i won in the art contest.
    -face pannel
    i cut some brackets for the feet to join to... probably glue..
    they still need a little bit of sanding but they are not done
    fit like so
    then i cut 2 brackets for the cd rom to screw into
    not drilled yet..
    this is what the front will look like just with a cut out for the cd rom part
    the cd rom fits really snug
    i then marked out all 4 pieces of the feet ready for cutting
    then today at school i cut 2 of the 4 pieces.
    then did a mock up to see how they fitted
    that is all... hoping to get the second side pannel done this weekend but may not.
    enjoy
    you tease!
    Balhannah, South Australia
    Nice start and nice cuts. Reminds me of another mod I have seen.
    Project: Elegant-Li *NEW*
    Project: Alpha FINISHED
    Sep 2006
    got the other 2 short feet parts cut.
    and also filed down a few brackets..
    thats all for tonight
    you tease!
    Jun 2008
    Adelaide
    Lookin' good. Maybe time for an update?
    Anodized VitzĄ^'s Avatar
    Nov 2008
    Durham UK
    like the window muchness :nod:
    keep up the good work
    Sep 2006
    lol updates tomorrow night have been working on side pannel...
    its not a window its a vent because its gunna have a piece raised up about 2cm over it.
    ill show you when i get more materials.
    you tease!
    Nov 2008
    Durham UK
    Quote Originally Posted by DonT-FeaR View Post
    Suppose that makes sense given the mod name
    /slaps himself
    GIVE ME THE CAKE!!! p0Pe's Avatar
    Aug 2007
    proud dane!
    duuust filters
    is that a 120.9 raddy on your case, or are you just happy to see me?
    METO V.1
    METO V.2
    METO V.3
    PC-Beto
    Project M8 [WIP]
    Sep 2006
    /\ oh yeah... didnt even think of that... any ideas?
    you tease!
