well i have upgraded to photobucket pro and now have unlimited bandwidth! so the pics are back up!
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
lol thanks the boy 4rm oz
And on to the next update
well I got some more bolts to do this project
so I fixed the angle pieces to the pump/res module
I then picked up where I left off on friday, the dvd supports,
I marked out the black pieces
Then all cut
Filing one
Sanded
And polished
And then this is how it will be supporting the dvd drive,
And the second one done
Thats it for today a little bit more tomorrow.
Josh
If you want a really high gloss finish on the plexi edges after you wet sand and buff run a lighter flame along the edge, you will get an awesome high gloss finish. Practice on a scrap piece first, you don't want to burn the plexi.
with my grinder/polishing mop i do get a really high gloss its just hard top capture it with my compact
Yeah I could tell from your pics that you put a lot of effort into your polishing. Just saying the flame polishing is a good thing to try. It is a whole different level of shine.
nah i have tried it before and i just cant seem to get it right so i will stick with the way i know how thanks guys
Hey there again guys
on with the next update!!!
This morning i went out to my local screwfix and picked up some safety goggles and a mask so that i dont keep getting bits of acrylic and metal landing in my eye and mouth....
i then got the third support for the dvd drive done
and then the fourth
this is pretty much how it will look just with the dvd housing raised a bit
and that is unfortunately all we have time for.
Josh
