my onboard internet wont work
the onboard internet port of my new nforce 680i LT motherboard lights up but i dont get a connection, im using an Old internet card right now for internet
All advice is appreciated
Re: my onboard internet wont work
i dont know what to do plus windows troubleshooter doesnt help at all
There's no conflicts? Allso, check the female plug on the motherboard, to see if any pins are messed up. Probably not, but you never know.
ok i checked, theres nothing wrong with the plug, i dont understand its a brand new motherboard
The people working in the sweatshop in china must have messed up on something, I guess.
lol maybe maybe not when i plug in the cable the orange light does come on but nothing else happens
Did you try manually setting the IP address?
im not sure how to do that, im still new at this
Maybe I can explain the process tomorrow. Right now, I have to go to bed. It takes a while to figure out on your own.
ok thank you for your help
