After working on this case as "The Mirage" for months and not getting the result I wanted, I decided to tear the entire thing down and start from scratch. Here is what I have so far.
My goal with this case is to make a fairly small PC that houses a full ATX board, SLI cards, watercooling, dual hard drives, and basically an all around high performance PC, while still maintaining a small size and looking good.
I started with this. The husk of the original Mirage. Note the bottom mounted radiator holes, which ended up blocking my PCI ports. This just won't do. Today, I will be cutting the holes for mounting a radiator up front.
I had to get all of my tools together, the paint, acrylic, tools, etc, and of course the Mountain Dew.
First I cut out the existing holes in the front of the case for intake. I didn't need this to be clean because it would not be shown.
Next I had to cut out the bottom bay of my drive rails, so that I could fit a full size 240mm radiator up front.
Finally, I drilled the holes to mount the radiator in the front of the case.
I will post more pictures tomorrow morning, I will be doing the paint as well as interior prep.
