Over the years I have been very slow to learn that I can actually learn from the experience of others. I had to get burned myself before I would believe that the fire was hot (literally and figuratively). I am hoping to hear the voice of experience here.
Building a new system and wondering about the PSU. I will be buying a 750-watt modular Ultra PSU:
http://www.tigerdirect.com/applicati...3596&CatId=106
Specifications
AC INPUT 115V/230V - 60/50Hz
DC OUTPUT +3.3V (24A) +5V (28A) +12V (25a) +12V (28A)
-12V (0.8A) -5V (-) +5VSB (2.5A)
750W Max Combined Watts
It has dual 12-volt rails and all the connectors and cables I will need. I will be running an Athlon 64FX processor, three fans, a low-end PCIe video card (but should include the power to upgrade later), several lights (figure ten CCFL's) and a plasma ball. Pretty sure it has the total wattage I need but the amperage is my question. I had originally purchased a 400-watt PSU similar in many ways but:
http://www.tigerdirect.com/applicati...p?Sku=ULT33162
Specifications
AC INPUT 115V/230V 10A/6A 60/50Hz
DC OUTPUT +3.3V (30A) +5V (32A) +12V (16A) -12V (0.8A) -5V (0.3A)
+5VSB (2A)
400W Max Combined Watts
I can use both of these if necessary, the lower-wattage PSU for my accessories for example, but would rather use the larger one alone if it will suffice for my needs. I am designing the build around my components so I need to decide how many PSUs it will have before I cut the rear panel.
So, bottom line, will this 750-watt PSU do everything I need it to do, or do I need to add this 400-watt to it to handle some of the load?
