help with flash player
Hello all i am having trouble with my flash player when i got to utube it says i eithier need to update flash or something in my java is messed up.
Well i tried to download flash and there was just a red x in the upper left hand corner so it said uninstall old version i did still nothing i went and searched google it said to update jave that worked fine .
When i try to install flash still red x i tried changing active x that the recommened still nothing on ie 7 is the browser btw .i dont know what else to try except a reinstall of windows which lol im really would rather not do
Re: help with flash player
hmm, strange problem, dunno what is happening, but I suggest using firefox, never had any problems with it, and when you don't have the right plugins you can install them very easilly. I would try that before re-installing windows...
hope that helps
thanks for reply i was thinking about that but im confused theres a mozilla.com and a mozilla.org what s the diffrence thanks for reply +rep
I think the .org is more the mozilla-company website, while the .com website is for the downloading. either one is the right site. Mostly when I need to install firefox I just type in 'firefox.com', it'll also direct you to the download-site of firefox.
hey thanks sorry it took so long to treply thanks again for help
Whenever I've encountered that problem in the past I had to disable Java - restart the computer and try to upgrade flash player again.
Hope this helps,
Agnat
hey thanks i will keep that in mind the next titme thanks again
