i know you guys are usually against commercial wc kits, but thats no big surprise, after all this is a community for people that like to piece together your own stuff.
with that in mind, any of these kits good enough for a first timer doing wc with a budget?
link
and yes i know you get what you pay for. so i know those arent the best of the best. but i'm sure one or two should be decent....right?
tax season didnt go that great so there's not enough for a new project, just enough for upgrades so i figured i'd wc either of my pc's. my vid card dont need to be water cooled so all i basically need is a rad, block, pump and reservoir. fittings, tubing and coolant is available at work.....
