Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
Thread: QX9650 Cooling System Help Needed!!!
  1. #31
    Default Re: QX9650 Cooling System Help Needed!!!
    thats to small and made by thermaltake, they couldn't make any water cooling product to save there lives.
    you can mount a 240mm like this
    Doesn't that block all of the plugs for like the video card and any other card in the back?
  2. #32
    . Spawn-Inc's Avatar
    Feb 2007
    ya i would think so, i would personally move it up one (so it covers the psu) it should be far enough that it won't block stuff.
    Sound: Logtiech Z 5500
  3. #33
    Hi,
    Has anyone tried the Asus SilentSquare Evo on a Striker II Formula?? I dont know if it fits! Does anyone knoe if it fits???
  4. #34
    Anyone?????
  5. #35
    Fox Furry crenn's Avatar
    In the shadows behind you
    Best way to check is to search on google or buy it and see if it fits.
  6. #36
    Feb 2007
    or email asus, since it's asus made though i would think it should fit all there boards. it looks small at the base were the heatpipes are.
  7. #37
    Thanks. I am going to check with asus because I read reviews from people on newegg and some said that it did not fit their asus board so... that is kind of weird.
  8. #38
    I tried in the ASUS forum and no one is replying... So I am back to see if anyone else has tried the Silent Square Evo with the Striker II Formula. Thanks in advance! Cheeese
