Are you sure? It is a very powerful CPU, but the good thing is that it does not generate a huge amount of heat. But still are you sure it does not need a more powerful heatsink?
More 'powerful' heatsinks will keep it cooler, but almost any heatsink can cool it enough if you don't plan on overclocking.
hi, Thanks for your reply
If I do plan on overclocking then what would be a good heatsink. Also what is a safe temperature to run the CPU at? Maybe the ones I have written about before? Anyone who has had them? I have listed a few that i have looked at. I could go up to max $200 but that is my maximum. Something way under that would be great.
THANKS
CHEESE!!
Thermalright Ultra 120 Extreme is the best air cooler out there ATM. watercooling for CPU only (thats quality custom built) will run about 250 or so.
Sound: Logtiech Z 5500
As Spawn-Inc said, the best for air cooling is the Thermalright Ultra 120 eXtreme.
As for temps, if you keep it under 70c then you should be fine!
why not go for a ati 3870 X2 and save the bucks and get a better card?
is that a 120.9 raddy on your case, or are you just happy to see me?
METO V.1
METO V.2
METO V.3
PC-Beto
Project M8 [WIP]
So you seriously just spent the most money possible and didn't even consider cooling until later...
As said a Ultra 120 Extreme should do a good job, but really if you intend on overclokcign then you would look at watercooling.
I would second the watercooling way if you plan to overclock. For me personally, i would never buy a $1000 processor and run the risk of overheating because i overclocked it on a sub standard air cooler. Water should bring the temps down by 20-30 degrees over an air cooler.
J-Roc, I wouldn't be so sure
My HSF is doing a good job, and the temps are similar to a basic water cooling kit.
It depends on the watercooling tbh. You need a good WC kit. Thats a good pump and at least a 360 rad etc.
