i have this really cool looking red LED which i wanna put into my dell for a really cool light effect... but, i do not know how to even hook up the darn thing... i hooked it straight up to a button cell battery, nothing... HELP!!
Optimist - The glass is half full
Pessimist - The glass is half empty
Engineer - The glass is twice as big
Me - There is water in a glass, deal with it
What color is it? different LEDS use diffrent voltages.
i think that you missed that part :pOriginally Posted by legoman786
anyways, red LEDs use about 1,5V so you need a resistor to get the spare Voltage away
you could hook it up in a molex you aint using for any part of your comp, but dont know how exactly, i've never done it before either
btw are you familiar with Ohm's Law?
http://metku.net/index.html?sect=vie...calc/index_eng
^^ thats an "LED Calculator" enter in the voltage of the LED, voltage of power source (12 volts), and the current in mA. click "calculate"
i dont know how much power the LED draws, and whats the Voltage Drop Across? how do i calculate how much mA -- I'm confused, I think I shouldnt even do this without knowing more about LEDs, sorry I took your time. Thanx anyway
Oh you want to know about LED's
Points you to http://linear1.org/
Read though the LED center and then hit his LED Wiz..
But in a nut shell
typical LED draw from 1.5V to 3.7 depending on what type they are. And you would use that for the Voltage Drop (as it is taking that much power from the source)
also most LED I have come across use 20mA (There are some that use 10 or more) But again that is a good place to start.
using the 1.5 and 20mA is a good place to start. If it doesn't light up 1st try turning the LED around as DC power flows one way and a LED will light on only if the power is flowing the right direction.
Erm - if it was a 3v battery, and a 1.5v LED - all the advice in the world aint gonna help ya - you sure you didn't blow the LED?Originally Posted by legoman786
the metku calculator says you need a 525 Ohm resistor, get one as close to that number as possible, one that is higher so you're on the safe side
and if you had read what i said you would have found out that red leds use about 1,5 volts and you would need about 20 to 30 milliamps
I bet if you do a google search, you can find a nice tutorial for how to hook LEDs up to PS w/ or w/o a switch. Ill try to find one.
"It's time to prove to your friends that you're worth a damn. Sometimes that means dying, sometimes it means killing a whole lot of people."
wow, lots of help guys. now i can actually mod my PC, YAY!
