hi all this will be my first tutorial ill be using come uv reactive sheathing and heat shrink with some new uv reactive molex plugs to tidy up my messy wiring. also adding 3 80mm uv fans to my uv case.
this is my case at the moment im awaiting parts to come from many suppliers
heres a list of wat i have on order
2 meters of red and 2 meters of yellow 11mm/6mm sheathing and 1 meter of green 16/10 mm sheath i did order a little to much but least i have some spare i may also sell this psu when im done if anyone likes it as ill be doing another tutorial on making modular PSU
50 male and 50 female molex pins as i will be shortening some cables a removale tool for the pins
3 x 80 mm fans uv one for the top front and rear of my case
10 green uv male molex plugs
10 uv blue female molex plugs
and a uv reactive blue powersupply connector kit
plus some red heat shrink
my plan is to power the top fan my dvd drive and the front fan off one 12v line and the 2 drives and rear fan off another sheathed in red
the power to mother board via 24 pin plug will be using the larger green sheathing and the cpu fan and other 4 pin mother board connector will be in yellow along with the wires which go to the power and reset buttons on the front and the dvd drive sound cable back to the mother board. i ordered it all on thursday and as it is now the weekend in australia i wont get it all till at least monday im going to upgarde to sata drives soon to elimate the old ide calbes so this mod to the psu is only a temp thing as ill need to get a bigger PSU when i get the sata drives and my dream mother board
EVGA 680i SLI Motherboard 122-CK-NF68-A1
linky
