Results 1 to 6 of 6
Thread: molex connectors and cable
    Sep 2007
    Cornwall UK
    Default molex connectors and cable
    ive been looking to buy some molex connectors and the wire to go with it
    so i can make my own custom length molex power leads,
    thought they would be easy to find on ebay or google no luck though,
    any links would be apreciated
    thx
    Jun 2006
    In the Redwoods
    Default Re: molex connectors and cable
    Depends on what connector you want. If you want to build your own 4 pin HD/CD/DVD power cable, you can find the connectors at frozencpu.com. The rest of them can be hard to find.
    Here is an example uv kit;
    http://www.frozencpu.com/products/36...tl=g35c183s283
    Sep 2007
    Cornwall UK
    thx Airbozo but im in the UK and i woulda thought it was easy enough to find standard
    4 pin molex connectors for cd/dvd drives here,
    they probably are and im just rubbish with google
    Anodized Roughhouse's Avatar
    Aurora, IL
    Try Jameco. They supply all shapes and sizes of molex. You do have to purchase teh pins seperately, but it gives you the flexability to choose what you want .
    http://www.jameco.com
    Look in either computer products or interconnectors. I have been having good luck with everything I have ordered from them so far.
    "You're so wise. You're like a miniature Buddha, covered in hair. " - Ron Burgundy
    t3h f3cKiN 33Ji7 calumc's Avatar
    May 2007
    Co. Sligo, Ireland
    Gut8, I know for a fact that maplin have them.
    Or else it should be easy to get some cheaply from ebay
    Quote Originally Posted by Crazy Buddhist View Post
    I'm starting to worry that I may become genuinely funny at some point. Then there will be no hope.
    Sep 2007
    Cornwall UK
    Roughhouse that looks like a good site but if i can ill get some from the UK, thx for the link though.
    calumc after another look i did find them at maplin, my original serch for 'molex connector' only came up with the UV ones.
    got to admit i was suprised at the price i woulda thought these things would cost pence not £1.09 for one
    and ive so far only been able to find one person on ebay that sells them and they sell the plastic housing and the pins seperatly !!
    ive bought 5 for now but i still need to find the cable for them but not getting anywhere
    not sure what the cable is called or what rating ect i should be looking at
