Page 5 of 5 FirstFirst 12345
Results 41 to 44 of 44
Thread: Frequent Wireless Disconnection
  1. #41
    Fox Furry crenn's Avatar
    In the shadows behind you
    Default Re: Frequent Wireless Disconnection
    Got a fan for the router yet?
  2. #42
    Try every channel to see what one works best - as changing channel seems to have helped. This implies interference was the cause of the problem.
    Get a USB wifi adapter then you can move it around to find the best signal. Higher signal/noise ratio = less dropouts.
    Some routers have the wifi on a daughterboard. These can slip lose and cause random disconnection. Opening up the router And checking its all well-seated can solve this.
  3. #43
    ^ Soon to be one. Computer-Geek's Avatar
    Nov 2006
    New York
    Quote Originally Posted by crenn View Post
    No not yet.
    Quote Originally Posted by Crazy Buddhist View Post
    Have any usb wifi adapters that you recommend?
    - Computer-Geek
  4. #44
    Quote Originally Posted by Computer-Geek View Post
    I'm using a Belkin one. Really cheap it is. When I was in the hospital the built in WIFI got 1 bar signal and used to drop out, drop packets and slowly load web pages whilst the Belkin one I had on a usb extension stuck upside down like a bat from a steel beam (held with scotch) - got 5 bars and never dropped out.
    It's a FD7050 wireless-G adapter and costs aout $60 in the UK.
