Is there a way to quiet this thing down? When I have bf2 up, it sounds like my mouse is speaking Xhosa
don't click it?...
if you click it a bunch of times it might wear it out a bit which should reduce noise. maybe open it up and put a thin rubber pad in between the mouse button and outside plastic button.
Sound: Logtiech Z 5500
Mice tend to get louder, I've found. I have the same mouse from ~6 years ago and it's louder now than it was then. =/
like i said try opening it up and put a thin rubber pad in between the mouse button and outside plastic button. i think it clicks so loud because it resinates the sound to the plastic shell.
