Results 1 to 4 of 4
Thread: Improving the vegetable oil case
    How much faster can you render the bsod? Ap1thy's Avatar
    Jun 2007
    New York
    Default Improving the vegetable oil case
    I was thinking while i was bored in school today and remembered an aluminum case I saw on frozencpu that had heatsinks built into the case. I remembered the vegetable oil vids on youtube and i was just wondering if a vegetable oil solution would work on a case like that, have the top act as a raditator of sorts and the case would be all aluminum so heat tranfer would be obviously a lot better than in an acryl case. Just have to mount the disk drives on top because the oil would get inside and mess up the motors
    dont have the money to do such a thing or feel like risking my new computer but its an idea
    . Spawn-Inc's Avatar
    Feb 2007
    Default Re: Improving the vegetable oil case
    this one?
    i think it wouldn't be worth the hastle trying to water/oil proof that thing.
    Sound: Logtiech Z 5500
    Jun 2007
    New York
    http://www.frozencpu.com/products/63...-1K614-A1.html
    that one... i agree it would be a pain, even for this one. itd be better to just make a case from scratch, i was just trying to give an example of the fins on top
    May 2005
    MO
    Your best bet with a case like that is putting plex or some non-reactive(non-ferrous) metal over the fan grills and caulking it into place.
    Also, make sure and caulk around the window.
    Before you caulk the card slots in, install your mobo and vid/sound/whatever card setup.
    Use marine caulk, like they do for fish tanks. It will hold, won't degrade in the solution and is designed to be a great sealant against leaks.
    Oh, and DO NOT USE plant-based oils! They will turn after a few weeks and become rancid. You will get some nasty, nasty smells & floaters in your solution.
    Use mineral oil instead. Since it isn't derived from plant matter, it will stay good for a long time and won't degrade or separate.
    Consider cutting/removing the top of the case for easy access to fill.
    When doing your first fill, put down a towel or several layers of absorbent material. Oil leaks are nasty. They're horrible when it's a seal at the bottom of the case and it's full.
    It's a good idea to keep a tub during your first fill or two just in case it leaks and you need a quick place to let it run out.
    Then, wipe it all down extremely well, remove the caulk around the leak, recaulk, and retry. It requires a lot of patience and a good set of nitrile gloves work wonders in keeping all that oil off your hands. Just be careful handling components, your hands are slick and it's easy to drop them. Oil all over your floor or clothes isn't much fun.
    Do not use ball bearing fans, they will burnout sooner than sleeve fans in immersion cooling.
    You don't need a processor fan. You do need a fan that moves the oil around. A sleeve high-cfm 120mm fan will do well enough, just make sure to test it in the oil before turning everything on. You don't want to literally fry your machine to death.
    I hope this helps. Immersion cooling makes a lot of people trepid. It's not difficult, just time consuming and can be very messy. Good luck.
