READ ME FIRST
Rule #1 Threadcrapping WILL NOT be tolerated
Rule #2 Stupid questions will be ignored
Rule #3 Lowball offers will also be ignored
Rule #4 Direct offers to email, do not PM
Rule #5 Rule breakers will be castrated
I accept Paypal, money orders, cash, sex (offer valid for female members 18 and over, under 125lbs not applicable in alabama, utah or texas, state and federal taxes still apply)
*Denotes newly added.
Shuttle Specific (or goes good with a Shuttle)
Shuttle XPC case covers, Black $35
40mm-60mm blue UV fan adapter $5
put a larger fan on your north bridge! or PSU
*Silver G1 case, no mods, has round rear grill instead of $40
perforated. looks to be in great shape
Black SB75G2 case, no cover $40
3 audio ports and mini firewire. I.C.E. grill removed, holes
drilled for a 92mm fan while retaining the mounting points
for a stock 80mm. Rail dremeled to allow for a sideways
HD install. Does not hamper anything.
*Black Aluminum bezel for two laptop drives in 5.25" bay $40
comes with all mounting hardware\screws\e.t.c.
*Shuttle SPDIF ports (these are universal for all models) $15
*Shuttle "Happy" feet (also good on normal cases) $10
Chrome, heavy, shiny, strong, cool!
*New Silent X PSU $65shipped
*New 200W PSU $45shipped
*Panasonic slot load laptop drive DVD\CD-RW Combo $45shipped
add $5 for IDE to laptop adapter
Misc. Shuttle cables, LMK what you need
Hardware
*Saitek Eclipse Keyboard, Silver\Blue LED $40
*Nvidia FX5700 256mb with VIVO, upgraded heatsink\fan $100
can run stable passively if NOT gaming. pretty new
*Asus Ti4600 with VIVO $85
*GeForce3 Ti 500, pretty new $65
10gb Hard Drive $20
Black Lite-On 52x CD-RW LTR-52327S $30
bought them thinking they were combo drives
Black Lite-On cd-r\w I think its 32x24x32. $25
not that much slower than 48x good for data burning
Black Floppy Drives $10
Mitsumi 7 in 1 Card Reader\Floppy 3.5" - Black $30
10\100 NIC cards $15
56k internal modems $15
Enlight 400w PSU $40
GOOD quality PSU, pretty newish, heavy, solid
Fanless VGA card, nVidia $15
currently in my tool kit to diagnose systems with, works well
15.7" LCD, SYS branded $180obo
Very nice silver monitor, modified stand (now it really is only 5" deep)
NEW Noblesse Case $80
installed stuff in it once, didn't quite like it, still has the protective
film over the blue mirror front. comes with all the original accessories
I replaced the LEDs with blue ones, dual blue LED rocker switches
installed behind door, looks like it was stock.
NOTE This is black NOT the grey version below.
http://www.modthebox.com/review6_1.shtml
*NEW Dell XPS Case w\480w PSU, Blue $100
Comes with the correct fans, looks awsome
Beige ATX case $40
dual front and rear 80mm fan mounts dremeled out,
two more on top and one on the side
Plain Beige keyboards and mice $10
or FREE with any case or motherboard purchase!
*PC Repair Kit tool, all bits store in handle, very handy $20
has about 20 bits (phillips, slotted, torx, hex, sockets)
Also ratchets clockwise or counterclockwise
Mods, Fans, Fan Controllers, Lights, LEDs
*Panaflo Steel Fans, these are the ones you've all been after $30
BACK IN STOCK
They haven't been manufactured in over 10 years! I have a
VERY limited amount of them so get em while I got em.
VERY rare and very quiet.
add $5 if you want them tailed
add $7.50 if you want dual tips (seperate RPM & PWR)
add. $2 for fan screws
add $3 for chrome grills
add $3 for grommets
*Price is now fully loaded
http://forums.bit-tech.net/showthre...87&page=2&pp=20
*Custom Fanbus \ Junction Box. 8 spring loaded clips $25
for 4 fans, or 8 using two fans each. Great fit and finish
I rolled out 25 of these and have a few left. check fanbus.com
for details, they are pretty much the same. Main power cable
is about 18" so you can mount it in a central location. I am
NOT currently providing custom units but e-mail me and if your
nice I might change my mind.
Sunbeam Internal baybus, lights up blue, 4 Molex ports $15
40mm Clear fans w\Blue LEDs x2 $10
Coolermaster 80mm Fans VERY quiet $10
Thermaltake Smart Fan 2 $10
*SVC UV Orange fans $8 or 3 for $20
*Blue slot fan, nice and quit yet pushes 40CFM $15
I think I rewired it for standard fan connectors (3 pin)
*Socket A Thermaltake Volcano w\smart fan 2 (copper base) $20
1 Blue 1 Silver
*Socket A Coolermaster HHC heatpipe cooler $40
*OEM Athlon XP coolers $15
Antec clear 120mm fans with blue LED $15
*60-80mm Chrome fan adapters, shiny, reflective $10
*80-120mm Fan adapters, Blue UV $10
Zalman Fan Mates 1 and 2 $10
Enermax 3.5" Fan controller UCA3FATR2 - Black $25
http://www.enermax.com.tw/products_...8&Gid=1&Gid2=21
PCMods 4 port baybus kit mounted on black bezel $20
low\off\high toggle switches w\LED indicators
includes mounting template incase you want it on another bezel
(fits 90% of the cases I tried it on)
Mitron 6 port baybus - Black Aluminum $45
low\off\high toggle switches w\LED indicators (fits ANY case, mounts with screws on the rails)
compare at $28.99 for the bare unit +$22 for the aluminum cover +$10 for the connectors =~$60!!
http://www.mitron.com.tw/product_ph...cat=232&id=1605
BLUE Sound sensitive cold cathode kits w\inverter $5 each
buy 10 for $40
Clear blue PSU cover, never mounted UV reactive blue $10
PC Turbo timer ALUMINUM $10
small, keeps fans on for 1,3, 5 or 10 minutes after shutdown,
one silver, one blue with all wiring and diagrams
Military switches with clear red cover and red LED $10
3 Blue LED rocker switches, $20 mounted
in black or silver lian li aluminum 3.5" bay $10 for just the switches (3)
Lazer LED lights, blue or UV $10 each
3 LED variants and single ultra bright variants available
one of the UV ones is fully sleeved with UV blue and blue heatshrink
PCI switch with molex passthrough cable, $5
PCI switch with molex passthrough cable $10
fully sleeved in chrome\silver with silver heatshrink
Mini 4 port Fanbus, about the size of a postage stamp $10
4pin power IN, 8 screw terminals
round blue CCFL with switch and USB power cable $10
*Sunbeam LED projector, projects different images $10
anywhere you point it. (Alienhead, biohazard, e.t.c.)
Cables and Adaptors
Gladiator Cables 2 dual device and one floppy $40 set
these are sheilded and grounded and the best IDE cables
you can get period, you WILL see an improvement in performance
molex splitters, I must have at least 100 best offer, or free with any purchase
*molex 4pin extension cables
*Fan extension cables, 6" average length some longer
*Fan power cable splitters, I've used to fans hooked to one mobo header
IDE Cables, various lengths, a few silver rounded high
quality units and ALOT of plain ribbon cables
Floppy cables also available, a few with the cool
orange ends with the snap in connectors
Bay covers, lots, beige, carbon grey, Lian LI
can vinyl dye anything black
USB cables - various lengths and colors
Silver UV reactive round cables x 3 $5
Black UV 10" IDE (not the crap rubber ones, like black braid) $10
Blue under UV
PC Power cables black, grey, white, have jillions. Free with any purchase over $25
Super flexible white PC power cables
Super long PC power cables with right angle plug (maybe 15ft)
USB/Firewire to power jack cable? plugs into a small inverter $10
to run CCFLs outside the case, comes with a round blue CCFL
Misc. fan cables
Fan Splitters with RPM support
single tailed connectors
extension cables, 6, 8 or 12" lengths both power and fan
Fan to 4pin converters to use a rheobus\fanbus with a 4pin fan
Fan screws, pushpins, grommets, grills, have lots of everything
Misc.
NEW HP 6110 All in One multifunction printer\scanner\Fax $175 pick ups only
this is the newer model, I believe the change is a 4800x1200 dpi
PMCIA to PCI adaptor, use laptop cards on your system! $35
Wireless modem, comes with laptop card and PCI adaptor $40 for everything
modem sits by the phone jack while the card is in your laptop
or PC with the adaptor 56k. Will also throw in a desktop card
then both cards can use the modem and talk to each other
like a network, extra secure since its not 802.11b or g!
Dell 2001FP monitor stand, BRAND NEW $50obo
Dremel 396-03 Complete Kit NEW $50
received as gift, used 3 times.
JVC automatic tape deck,- Silver $65obo
press a button and it slides out like a cd-rom drive,
dimensions and that of a shuttle and maybe 3" high,
was going to mod it into a case but decided not too,
dolby, auto reverse and alot of other features.
I paid over $200 for this since I like good audio.
NEW KVM switch, blue, with clear blue cables $25
Altec Lansing Speakers w\subwoofer $40obo
AVS3000
