Results 1 to 7 of 7
Thread: Mod case to fit 120mm fan
    Sep 2007
    Default Mod case to fit 120mm fan
    I want to fit a 120mm rear exhaust fan, my current case has 80mm and 92mm mounts, is there anyway to do this ?
    Austral Alien
    Jan 2007
    Newcastle, NSW, Australia
    Default Re: Mod case to fit 120mm fan
    Quote Originally Posted by 123123 View Post
    Yep!
    Assuming the case is wide enough for it, you just need to cut a bigger hole for it with either a dremel or a jigsaw and drill new mounting holes.
    Quote Originally Posted by Crimson Sky View Post
    hahaha..."Wacky"
    -Wackello Capello
    Sep 2007
    Okay so I just measured and I can't fit a 120mm fan. Would this product work? http://www.sharkacomputers.com/fanad8012fan.html of course I would want to mount it on the inside of my case.
    I got rid of my floppy disks Xpirate's Avatar
    Apr 2007
    Texas
    You can use an old scratched CD to use as a template for the hole. I learned that from someone else on this forum.
    Apr 2007
    Texas
    Okay so I just measured and I can't fit a 120mm fan. Would this product work? of course I would want to mount it on the inside of my case.
    Your link was messed up. That would work okay. But you might have an issue mounting it on the inside because of the size difference.
    Austral Alien
    Jan 2007
    I doubt it will fit using that. Looking at the picture inside the case, I would say a 120mm fan, plus that mounting bracket would foul your heatsink.
    Why not just get a 90mm fan and be done with it? How come you need a 120mm?
    hahaha..."Wacky"
    -Wackello Capello
    What you could do is make a triangler prism out of aluminum sheetmetal.
    Give it just enough angle so you can mount the 120 fan on the longest face. Mount the box to the back of the case with sheetmetal screws or pop rivets.
