do you think it would be ok to cut a window with a plasma cutter or should i not
Depends if you like you window:
Melted.
Flaming.
Damn right ruined.
unless if your talking about cutting the case, then sure why not, if you got the cutter, mine as well use it.
LOL, I am now an "ATX Mental Case" . 100+ posts!
what is a plasma cutter?
i dont have one but my neighbor has one and will let me use it
Originally Posted by emochild626
a very expensive tool.
http://www.plasma-cutter.com/
Plasma cutter would be fine on the case.. Not the Acrylic (that would melt into a gooy mess.
what person would use a plasma cutter on acrylic
you'd be surprised the manner of silly people out there...
overheard two construction guys once:
"hey, what kind of nails are you using? these arent going in very well, whats the deal with them having a dent in the top anyhow?"
"you're trying to hammer in screws again."
True story.
whats a plasma cutter it sounds lethal and how expensive
