So, I bought a second hand mobo and CPU on eBay. It's an Asus K8V-VM / Athlon 64 3000.
I needed some RAM so I bought one 1GB DDR400. ebay #270151489681 having checked for compatibility.
The chipset is the VIA K8M890 which is on the compatibility list, but something isn't right.
It POSTs ok, recognises the 1GB and starts to boot but then stops. I tried some memory diagnostic software and it failed. I've emailed the seller, and he basically just sent me the same data on the listing. I confirmed that the chipset on my board is listed, and explained the problem. I'm waiting for his tech support to get back to me.
The seller's return policy sucks. If it's incompatible, he'll take £10 and return the rest.
I feel that if it's incompatible due to his incorrect listing then I ought to get the full price back.
Meanwhile, I can't use the computer. I'm tempted to take it to a local shop and just buy some memory there and test it in the shop. Just in case the problem lies with the motherboard...
If I do go this way, I might be able to have them test the RAM in another board. If it's ok then I'd probably be better just selling it.
