Re: Random slowdowns -- Why?
That would point to something on your home network it would seem. Can't be an IP conflict as that would stop traffic completely and usually pops an error message. Do you have a dns set like google dns? Might be a dns resolution problem, if you aren't using open dns you might give it a try the addresses are 8.8.8.8 & 8.8.4.4
Yes, that's even WITH Google's 8.8s.
I'm thinking the router is simply wearing out.
AmEv
Yup time to try a new router.
what would be a good high quality router? mine keeps loosing it's ip address.
i think you could try use the wire connection to take a look, maybe it is because of the wireless, make a comparasion.
So good luck!
I suspect that - after four years - the OP has either figured out a fix for his internet lag or has just learned to live with it.
But, uh, welcome to TBCS, lol :rolleyes:
